Removing Valve - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-16-2012, 08:59 PM   #1
Removing Valve
I am working on adding a refrigerator line from the plumbing under my sink. I thought it would be as easy as removing the current valve and replacing with another. I cannot get the old valve off. How does it come off? Any ideas to make it cone off easier? I would like to keep the nut on and simply screw the new valve on. Is that possible? I am trying to post photos from my iPhone, but having problems...
Here are the photos...
Trying to replace this shutoff valve...
With this valve...
JdbAZ is offline   Reply With Quote
Old 05-16-2012, 09:05 PM   #2
Rewards Points: 582
well when we get a picture you will get an answer....
Old 05-16-2012, 09:58 PM   #3
Okay, hold the current valve with a wrench, and get another wrench on the nut behind the valve and turn it clockwise. It should unscrew and leave the nut and ferrule on the pipe.
broox is offline   Reply With Quote
Old 05-16-2012, 10:05 PM   #4
Rewards Points: 582
yep do just that
Old 05-16-2012, 10:16 PM   #5
Yep. Tried that until I felt I'd either break my arm or the pipe which made me think i was doing something wrong. I'm going to use white vinegar and maybe some type of lubricant to see if that helps.
Old 05-16-2012, 10:32 PM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Are you turning the valve clockwise or the nut?
Facing the valve, the nut should turn clockwise in order to remove the valve. If you're trying to unscrew the valve, hold the nut and turn the valve counterclockwise.
Also, what size wrenches are you using? Sometimes you might need a bigger one if it's been overtightened.
Journeyman Plumber
Old 05-16-2012, 11:47 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
If youre leaving the old nut and ferrul on the line its been my experiance anyway to wrap the new valve with some teflon tape before threading it onto the old nut.
Saves fighting with a drip from slightly mismatched parts.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 05-17-2012, 09:18 AM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 984
Fingernails and hands to clean, not qualified to do this type of work call a plumber.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Gas valve on a bryant heavyduty HVAC 1 12-16-2009 09:42 AM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 11:49 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 01:43 PM
