Removing Tub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2008, 11:27 AM   #16
the Musigician
DangerMouse's Avatar
after removing the old spout, you're back to hacking off maybe a quarter inch from the male to allow it to make contact with the wall.
let us know what you have when the spout is off.
DM
Old 11-17-2008, 11:57 AM   #17
So there is no way to attach it in a firmer way without opening the tile? The pipe feels very springy, not firmly held in the wall at all. If the spout is only attached to the springy plumbing, it would still be easy to pull the whole spout out from the wall even if I shorten the male thread to allow the spout to make contact with the wall. Wouldn't that arrangement be prone to damage to pipe and tile, and liable to allow water to get into the wall?
dummy14 is offline   Reply With Quote
Old 11-17-2008, 12:03 PM   #18
the Musigician
perhaps some silicone ADHESIVE caulk between spout and wall would do the trick? that should hold it ok and keep water form seeping behind as well.
DM
Old 11-17-2008, 12:07 PM   #19
Thanks, I'll give this a try. Given my degree of success with the first attempt, I'm sure my wife will get a tad skeptical when I bring out the hacksaw...
Old 11-17-2008, 12:13 PM   #20
the Musigician
-=chuckle=- maybe.... let us know what you find.
DM
Old 11-17-2008, 12:48 PM   #21
Custom Cabinet Maker
Dummy14; Warning Warning Danger Will Robinson!!!
DO NOT just hack thru that spout, If it screws on to a male adapter it may be closer to the FRONT of the spout than u think. I would get something to wedge between the spout and wall to make it as tight as u can, then split the spout LENGTHWISE NOT CHOP IT OFF. Spout is garbage but you do not want to damage the copper it is attached to. Even if after u get it off if there are parts left screwed onto that male adapter then take a hacksaw ( your best friend LOL ) and carefully cut into it until you can split the remainder off the adapter. Once all the old parts are off then you can see exactly why it is loose, fix that, than put new spout on.
You can get replacement spouts that DO NOT screw on, they have a setscrew underneath and only need straight pc out of wall. That way if need be you could cut off the male adapter,SAND SMOOTH THE EDGES, that is important, slide new spout on right tight to wall tighten setscrew wallah! all done.
skymaster is offline   Reply With Quote
Tub Spout Help showerhelp Plumbing 9 11-13-2008 08:15 PM
Bathtub Spout Leaks Behind Spout (pics) wallix Plumbing 7 10-14-2008 04:41 PM
Tub Spout Gap??!? Please help. Mayzee1 Plumbing 7 05-07-2007 04:32 PM
Need help with tub spout sherlock Plumbing 1 10-25-2005 04:19 PM
