Old 10-05-2010, 06:14 PM   #1
Removing toilet flange
I have a concrete floor and the toilet flange was very corroded. I was able to remove the metal flange, but the pvc part seems to be glued and wont budge. There were no screws holding the flange down. How do I remove the pvc part so I can replace it with a new flange?
rwilliams584 is offline   Reply With Quote
Old 10-05-2010, 06:34 PM   #2
i'm assuming your drain pipe is also PVC. PVC glue welds the two pieces together to form one peice. You will not be able to seperate it without cutting it apart. In your situation its best to use a replacement flange that uses a rubber compression fit gasket.
http://www.oatey.com/Plumber/Shared/...placement.html
acerunner is offline   Reply With Quote
Old 10-06-2010, 09:39 AM   #3
Good idea, just make sure it's properly screwed into the concrete. I like to see brass or stainless steel screws that don't corrode
the_man is offline   Reply With Quote
Old 10-06-2010, 10:18 AM   #4
Just call me Andrew
How does that replacement flange work? Does it fit inside the pvc pipe and squeeze outwards?
Do you have to just slice the flange off with a pvc cutter of some kind then push that one inside?
Andrew
secutanudu is offline   Reply With Quote
Old 10-06-2010, 11:42 PM   #5
yes, and yes.
The Following User Says Thank You to acerunner For This Useful Post:
secutanudu (10-07-2010)
Old 10-09-2010, 07:33 PM   #6
In case anyone was wondering how to get a pvc flange out, heres how. Cut off the top of the flange, stuff a rag down the pipe. once the flange is cut off, use a hammer and chisel to seperate the rest inside the pipe. use sand paper to smooth the inside out after chiseling and insert new flange. I broke my flange while trying to install a new toilet. Called a repairman out and watched him.
navman28 is offline   Reply With Quote
Old 10-11-2010, 06:21 PM   #7
Yes, I have replaced two using that technique.
jeruss is offline   Reply With Quote
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
Replacing basement toilet - what to do about flange mslide Plumbing 4 12-20-2009 08:54 AM
Removing 2" marble toilet flange adapter for handicapped proofer Plumbing 20 04-21-2008 05:31 PM
Removing Toilet Flange Downhill Plumbing 4 03-31-2008 04:14 PM
Removing old toilet flange craftycas Plumbing 3 02-22-2005 12:59 PM
