Removing Stripped 3/32 Allen Screw From Single Handle Delta Shower Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-03-2012, 12:49 PM   #1
removing stripped 3/32 allen screw from single handle delta shower faucet
I can't loosen 3/32 allen screw on my delta single handle faucet. Therefore I can't remove handle to fix the leak.
miguelsalcido is offline   Reply With Quote
Old 05-03-2012, 01:50 PM   #2
Rewards Points: 340
i would first try a small flathead screwdriver that you can maybe bang in there with a hammer (be careful) that will stick enough to break it loose and get it off. you can also try drilling it out (also very carefully) with a small bit.
NitroNate is offline   Reply With Quote
Old 05-03-2012, 03:47 PM   #3
Homerepairguy's Avatar
Rewards Points: 998
I don't know how you can remove a stripped 3/32" allen screw that's probably in a recessed hole since it's pretty small. But did the allen wrench round off while stripping the screw? If so, recommend that you dump that allen wrench set and buy a high quality set.
In my younger days working as a computer tech, we had to remove pulleys, collars, etc. from printers, card punches and other mechanical units. I quickly learned the difference between cheap, soft metal allen wrenches that rounded off and stripped screws, and high quality tempered steel allen wrenches that actually removed the allen screws. There is a huge difference!
HRG
Homerepairguy is offline   Reply With Quote
The Following 2 Users Say Thank You to Homerepairguy For This Useful Post:
ben's plumbing (05-03-2012), plummen (05-03-2012)
Old 05-04-2012, 12:42 AM   #4
You might be able to tap a Torx bit into the hole.
But, you must realize. It might damage the bit.
And you will probably only get one chance to break it loose.
Tap it in as far and as tight as it will go. It must be straight.
Use good strong leverage bar.
You will hear it SNAP when it breaks loose.
luck
jammin06 is offline   Reply With Quote
Please help, Stuck cartridge,Moen single handle tub faucet, Woodpecker Plumbing 25 01-26-2014 05:31 PM
Help Repairing a 25 Year Old Delta Shower Faucet shapeshifter Plumbing 5 07-07-2008 08:24 PM
Kohler single handle shower randy717r Plumbing 1 03-29-2008 11:35 AM
two handle shower faucet to single handle GLASSMAN1 Plumbing 2 01-31-2008 08:08 AM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 09:36 AM
