Removing Stack With Snap Cutters - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-18-2008, 12:50 AM   #1
Rewards Points: 150
removing stack with snap cutters
what is the best approach to removing an old iron stack from just below the second floor up using snap cutters?
drewhart is offline   Reply With Quote
Old 07-18-2008, 04:00 PM   #2
Start at the top. This way you don't need to support the portion you are not removing at the time. Cast iron pipe (the old stuff) is quite heavy. Doing it this way, you can cut the size pieces you want and can handle. There are 3 types of snappers. One has long handles and can be a pain in tight spaces. There are also ratchet handle cutters and hydraulic.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Tie into main kitchen stack gdub1973 Plumbing 1 08-02-2008 05:23 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
Distance to stack rusty_5620 Plumbing 4 02-22-2007 12:39 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 01:56 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
