Removing A Soldered U Joint - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-10-2010, 05:20 PM   #1
Removing a soldered U joint
How do you do this on a 1 1/2" brass pipe? When I heat up one side, the other side cools and won't budge. Is the only way to cut it off? I believe there is an indicator button which fell in and is blocking the flow. It fit quite snugly in the pipe and when I tried to remove it, I only succeeded in pushing it further in the pipe.
vitaeterna is offline   Reply With Quote
Old 01-10-2010, 05:49 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
got a picture,are you talking about a p-trap?
plummen is offline   Reply With Quote
Old 01-10-2010, 11:47 PM   #3
Yes, it is a P trap
A p trap is the correct nomenclature, though it looks more like a U to me!
Old 01-11-2010, 08:09 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 336
Ayuh,... You can't solder, or unsolder a joint, til it's Dry both inside,+ out...
If there's standing water in it, you Can't unsolder it....
Old 01-11-2010, 02:37 PM   #5
Plumber's solution
My original problem was that an indicator button had fallen into the drain and I thought it was in the p trap. The plumber came by and just pushed a snake through for $190.00. He said it is very rare to find items in the p trap, like rings or other valuables. He also said that it was very hard to get a p joint dry enough to unsolder. He said I would have been there for an hour boiling it off. Live and learn!
Tags
remove u joint p
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
soldered joint just starts leaking? red86yota Plumbing 2 05-08-2009 07:17 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Removing a soldered brass water cap? squid226 Plumbing 3 10-08-2008 01:25 PM
concrete joint leaking billie_t Building & Construction 3 07-24-2008 09:10 PM
