Removing Slicone Caulking On A Hot Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-28-2010, 04:08 PM   #1
Removing slicone caulking on a hot tub
I have a steady leak coming from the housing for the filter/skimmer on our LifeStyler hot tub. Can't plug it...it just finds another place to leak from. Looks like I'm going to have to remove the old silicone and take the housing apart to check "O" rings and the housing itself. Slicone is all over the threads as well as the housing from years of patching. Any good way to take it off?
mcdaddy45805 is offline   Reply With Quote
Old 06-28-2010, 06:01 PM   #2
Rewards Points: 1,216
Yes McKanica Silicon Caulk Remover in purple tube can be purchased at Ace hardware or True Value not sure which one. It destroys Silicon.
I used it to remove a sink bowl from a vanity it really worked, it still was a tough job.
Good Luck and check out the product on line.
COLDIRON is offline   Reply With Quote
removing silicone caulking Tooshadz Kitchen & Bath Remodeling 7 08-28-2014 09:47 AM
Caulking Exterior Windows unixb0y Painting 1 06-04-2009 06:31 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
Tuckpointing vs. Caulking NewUser1 Building & Construction 2 07-09-2008 09:33 AM
Removing caulking from tub CowboyAndy General DIY Discussions 2 04-02-2008 07:20 PM
