Removing Sink Pop Ups - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-01-2013, 02:24 PM   #1
Removing sink pop ups
Never had great luck removing the drain outlets on sinks. Is there a trick, I always end up just sawing them off. What tool should I use?
paintdrying is offline   Reply With Quote
Old 04-01-2013, 02:30 PM   #2
Rewards Points: 14,014
Little more detail, are you just trying to remove the pop up or the whole drain?
Both should be about a 5 min. job unless where missing something.
Got a picture so we can get an idea on why your having so much trouble.
Old 04-01-2013, 02:42 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 818
Is this a kitchen sink, bathroom lav?
Old 04-01-2013, 05:26 PM   #4
Rewards Points: 582
ks basket strainer and lav pop ups can be remover with a p.o plug wrench ..but in all honesty most of the ones we remove can be done with channel locks...ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
joecaption (04-01-2013)
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Resetting Undermount Kitchen Sink Voss Plumbing 0 02-24-2012 12:47 PM
Venting a sink pump WillK Plumbing 2 12-26-2010 01:21 PM
Suspended/Floating sink installation? How? techprincesse Building & Construction 3 11-21-2010 03:05 PM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 06:33 AM
