Removing Single-control Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2012, 08:42 AM   #1
Removing single-control kitchen faucet
Having trouble removing single-control kitchen faucet. Here is photo from underneath. I removed the water lines but the fixture would not lift off of the sink. Is there something I need to loosen in the middle hex shaped extension?
jrl124c is offline   Reply With Quote
Old 04-12-2012, 08:47 AM   #2
Rewards Points: 14,026
That hex shaped shaft unscrews.
Old 04-12-2012, 08:52 AM   #3
Thanks. There is a small set screw at the end of it. I removed it and inside the shaft there is what looks to be a square shaped bolt. Do I have to do anything with that, or do I just use a wrench to unscrew the outer hex shaft?
Old 04-12-2012, 08:53 AM   #4
Should have to just unscrew the hex.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
jaydevries (04-12-2012), plummen (04-12-2012)
Old 05-05-2012, 04:44 PM   #5
ok, got that. Now I'm stuck again, can't get the faucet apart. I unscrew the outside parts, but it just pops back and loses the thread somehow. Suggestions? Picture attached.
Old 05-05-2012, 04:56 PM   #6
For one thing you never unhooked the sprayer.
Old 05-05-2012, 04:58 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 834
Are you replacing all the faucet? If so, disconnect the spray house from the faucet. Also remove the nuts from the deck plate. The faucet should pull up out of the hole. One supply line will be slightly longer- this helps to get them through the sink deck hole, one at a time
Old 05-05-2012, 05:01 PM   #8
Sorry, what I;m trying to do is take the faucet apart so I can check the washers and mineral buildup. The sink is making a loud whistling noise. I'm not trying to replace the faucet, just take apart the control to get inside where the washers are.
Old 05-05-2012, 05:05 PM   #9
Plumber
Rewards Points: 834
In that case, resemble it and remove the handle. From there you can access the parts.
Old 05-05-2012, 05:17 PM   #10
thats the problem, can't get the handle off
Old 05-05-2012, 05:51 PM   #11
Plumber
Rewards Points: 834
Your method won't help. You have to back off the set screw at the handle
Old 05-05-2012, 06:23 PM   #12
I don't see a set screw, where is it?
Old 05-05-2012, 06:28 PM   #13
I=E/R
a7ecorsair's Avatar
You may have a decorative plug that has to be removed.
a7ecorsair is offline   Reply With Quote
Old 05-05-2012, 06:43 PM   #14
yes, there was a decorative plug, I removed it but I still cant find the set screw underneath?
Old 05-05-2012, 06:51 PM   #15
First re-install the faucet. There is a little cap/plug below where the spout connects to the faucet. Pry it out with a knife. Then put an allen key in there and unscrew it until the handle slides off. Then there will be a piece that holds the cartridge into the faucet. Unscrew that. The whole cartridge is replaced for free if its a Moen faucet. If it isn't just replace the whole cartridge. Make sure it goes in as described or the hot and cold may be reversed. Take it to a plumbing supplier or a big box store. I would replace the spout O-rings too.
sanec1 is offline   Reply With Quote
Delta kitchen faucet is leaking under the sink grave20 Plumbing 2 04-01-2012 01:00 PM
removing load-bearing walls and moving the kitchen WannaReno Remodeling 2 04-02-2010 05:05 PM
Crane two handle kitchen deck faucets Nestor_Kelebay Plumbing 1 06-23-2009 08:28 AM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 02:02 PM
Double Handle versus Single Handle kitchen faucet Lindahoney Plumbing 7 11-20-2007 09:36 AM
