Removing Silicon Adhesive - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-09-2012, 06:14 AM   #1
"Old" Newbie
Rewards Points: 177
Not sure if this the correct forum for this, but it's a problem, and it's in the shower, so here goes:
I had a shampoo/soap dispenser mounted on the wall (fiberglass) of my shower. It fell and shattered but I'm left with strips of stubborn silicon adhesive on the wall. I could probably get it off with a razor blade, but don't want to risk scratching the wall.
Any suggestions?
Thanks,
Rob
RCrosby257 is offline   Reply With Quote
Old 05-09-2012, 06:38 AM   #2
Lightfoot's Avatar
Rewards Points: 272
a razor blade is what i would use, very carefully. I don't know of anything that will dissolve silicone. Or you could get another dispenser and put back in the same place.
Lightfoot is offline   Reply With Quote
Old 05-09-2012, 04:01 PM   #3
Rewards Points: 1,216
Try McKanica silicone caulk remover. ACE hardware sells it. Other places might to check on line. I used it on a bathroom sink it seemed to work OK but you still had to work it hard.
COLDIRON is offline   Reply With Quote
Old 05-09-2012, 05:22 PM   #4
Rewards Points: 636
this link will work but still have to rub a lot when i used it even after scraping the thick spots. i also on some surfaces like acrylic i use cotton terry cloth and denatured alcohol
http://www.homedepot.com/Paint-Clean...&storeId=10051
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-09-2012, 06:05 PM   #5
The reviews on the Motsenbocker's are bad.
Removing adhesive from under old vanity top jdbs3 Remodeling 1 04-07-2012 08:42 AM
Removing Adhesive and Paint from Concrete onthejob Flooring 4 03-29-2012 10:11 AM
removing carpet adhesive before tiling ratherbefishing Flooring 1 01-11-2012 03:43 PM
Removing Granite & Omni Grip Adhesive from Fireplace Surround RayJak Tiling, ceramics, marble 4 11-13-2009 03:28 PM
Removing Vinyl Tile Adhesive from Linoleum The Raven Flooring 3 07-22-2008 08:38 PM
