-   -   Removing Silicon Adhesive (http://www.diychatroom.com/f7/removing-silicon-adhesive-143181/)
RCrosby257 05-09-2012 07:14 AM
Not sure if this the correct forum for this, but it's a problem, and it's in the shower, so here goes:
I had a shampoo/soap dispenser mounted on the wall (fiberglass) of my shower. It fell and shattered but I'm left with strips of stubborn silicon adhesive on the wall. I could probably get it off with a razor blade, but don't want to risk scratching the wall.
Any suggestions?
Thanks,
Rob
Lightfoot 05-09-2012 07:38 AM
a razor blade is what i would use, very carefully. I don't know of anything that will dissolve silicone. Or you could get another dispenser and put back in the same place.
COLDIRON 05-09-2012 05:01 PM
Try McKanica silicone caulk remover. ACE hardware sells it. Other places might to check on line. I used it on a bathroom sink it seemed to work OK but you still had to work it hard.
jaydevries 05-09-2012 06:22 PM
this link will work but still have to rub a lot when i used it even after scraping the thick spots. i also on some surfaces like acrylic i use cotton terry cloth and denatured alcohol
http://www.homedepot.com/Paint-Clean...&storeId=10051
COLDIRON 05-09-2012 07:05 PM
The reviews on the Motsenbocker's are bad.
