Removing The Shower/tub Diverter - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-05-2011, 06:13 PM   #1
Removing the shower/tub Diverter
Hi,
I've read a few threads on here about diverters and removing them. However nothing has worked with mine.
I have a deep socket that fits on the nut to the diverter and have tried to get it loose/out and everything has failed so far.
The unit is a 3 handle Gerber probably from late 60's. Is there a special tool for this? I really wanted to get this off and take it to HD to find a replacement rather than make two trips to get this job done. I've attached 2 pics
Thanks for your help.
Removing the shower/tub Diverter-house-001.jpg   Removing the shower/tub Diverter-house-002.jpg
Kathy65 is offline   Reply With Quote
Old 12-05-2011, 06:51 PM   #2
Rewards Points: 582
yes they are called tub wrench....but your socket should work also...what i do is chip away alittle ceramic tile so you have room for wrench or socket be careful not to crack tile ...this is going to be tight....sometimes really tight... but it should break free...take it out slowly watch for small ring washer...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Kathy65 (12-06-2011)
Old 12-05-2011, 07:00 PM   #3
Would the tub wrench work better than the socket? I've already had to chip away some of the tile on the left side (very very thin piece) to get the socket to lock on. Then I tried vice grips on the socket it slipped around it more than anything. So I tried a piece of rubber drawer liner on the socket, helped but still couldn't get it to break free. Maybe after my hands have a rest I can try it again. How about oiling it overnight, would that work or should I not bother? This is such a pain.
Old 12-05-2011, 07:01 PM   #4
Rewards Points: 175
also if a crescent wrench will fit in there that will work also.
Old 12-05-2011, 07:15 PM   #5
Rewards Points: 582
they are flush to the surface so you have to use a socket...you need 14-15"leverage bar on socket to break free....if you have pipe wrench lock in on socket push down with weight " NO DISRESPECT" remember your turning to the left.....
Old 12-05-2011, 07:25 PM   #6
Okay, so is pushing down with weight the key here? Or just helpful? I will try that with the socket tonight if it doesn't work, then I will have to go get a pipe wrench in the morning. I will let you know how it goes once I get it out.
Thanks very much for your help....oh, no disrespect taken, but yes lefty loosey is a must for removal.
Old 12-05-2011, 07:31 PM   #7
Rewards Points: 582
it really is helpful to you because it does take some arm strength......I have had my fill of theseover the years...glad to help let me know how you make out
Old 12-06-2011, 11:05 AM   #8
Yaay! I got it out with the use of the socket wrench thingy! Now, I have a question before I install the new one, How tight do I need to screw it in? And anything else I should know about putting the new one in?
Removing the shower/tub Diverter-photo-0312.jpg
Old 12-06-2011, 06:43 PM   #9
Rewards Points: 582
good job thats a tub wrench...if you can put alittle facuet lube on threads and reinstall snug it up you don't have to over kill it,,,,check for leaks...
Old 12-06-2011, 06:46 PM   #10
Thumbs up
Okay, I will do that then, So I don't need to put as much force to install it as I did to get it off?
Thank You so much for all your help with this, I really appreciate it!
Old 12-06-2011, 06:52 PM   #11
Rewards Points: 582
welcome ....thanks for the smile....yes just snug it ..that little red gasket seal easy......
removing bathtub faucet diverter xconx Plumbing 6 10-10-2011 12:17 PM
Remove V Shaped Rain Diverter Above Door? AllanJ Roofing/Siding 1 09-05-2011 03:39 PM
Shower Diverter questions... dgates12 Plumbing 3 07-29-2010 08:15 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 04:27 PM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 11:49 AM
