Removing Shower Handles So I Can Replace Washers - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-13-2012, 01:29 PM   #1
Removing shower handles so I can replace washers
I Have a set of shower handles that I can't get off!
I popped the caps, removed the screws. The handles will go so far but will not come the rest of the way off.
This house was built in the early 70s, so the handles are from that era or late 60s.
There are three handles. Hot, cold and the one that changes from shower to tub.
Thanks!
17thfabn is offline   Reply With Quote
Old 08-13-2012, 01:33 PM   #2
Rewards Points: 13,300
I put the screws back in and leave them loose and use a gear puller.
They also sell a puller just for this in the plumbing tool dept. at Lowes and HD.
Once they break loose they will slide right off.
http://www.bing.com/shopping/faucet-...M=EGCA&lppc=16
17thfabn (08-13-2012)
Pivoting Shower door replacement questions inspectator Kitchen & Bath Remodeling 5 07-22-2011 10:00 PM
Replace Shower Stall with Tub on Cement Slab Kat58 Kitchen & Bath Remodeling 3 03-10-2011 11:55 PM
Can you replace faucet handles without too much trouble? Snav Plumbing 2 04-13-2010 08:03 AM
Shower door pull handles loose RICK430 General DIY Discussions 5 03-29-2009 09:39 PM
Replace Gerber shower valve aacwaacw Plumbing 2 11-25-2008 04:20 PM
