Removing Shower Doors On A Tub - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2011, 10:21 PM   #1
removing shower doors on a tub
We just closed on a new house and the first thing I want to do is remove the shower doors in our kids bathroom. How can I do this? Will I have to make any repairs to the tub itself?
shocanfixit is offline   Reply With Quote
Old 02-27-2011, 06:03 AM   #2
Rewards Points: 352
first lift the door vertical and either swing the bottom out of the track or pop the rollers on top out of the track. Then remove all screws holding frame work, cut all caulking with utility knife or multi-tool if you have one. Fill all holes with a tub and shower caulk that matches tub. Try to sell old doors on local craig's list use money to buy pizza for family and you are the hero!!
plumberinlaw is offline   Reply With Quote
Old 02-27-2011, 08:29 AM   #3
Sides tracks usually have 2-3 screws in the wall, top track usually simply lifts out, bottom track is held in place only with caulk. The screws in the wall usually have plastic mollies, pull them out and fill as suggested above.
Old 02-27-2011, 08:35 AM   #4
DIY staff
Rewards Points: 7,174
Some tub doors have a plastic or aluminum clip (bottom track--center ) that need to be removed before the doors can be lifted out.---Two Philips head screws.
Fairly simple job---Mike---
Old 02-27-2011, 08:41 AM   #5
Builder/Remodeler
ChrWright's Avatar
The bottom track over the curb of the tub won't have any fasteners in it, but removing the caulk can easily mar the surface--even if it's glazed cast iron.
Hard water deposits can be very difficult to remove without chipping the surface of the tub as well.
Only use plastic scrapers to remove the caulk and you'll have a better chance of not scarring the tub. Hard water deposits can be removed with a little diluted CLR and some patience.
DON'T PICK UP THAT METAL PUTTY KNIFE.
ChrWright is offline   Reply With Quote
Old 02-27-2011, 09:29 PM   #6
Thanks everybody, I can't wait to get that door out of there! I will let you know how it goes.
Old 03-07-2011, 12:50 AM   #7
Master of none
Silicone be gone
All the other suggestions are correct. But removing the silicone caulk can be a pain. Some people never get it all off! I have found only one product so far that works well. Still time consuming! It is "Silicone be gone" made by DAP. I find it at most local hardware or building supply stores. Just follow the directions.
handy andy is offline   Reply With Quote
Removing an old shower pan kvn Kitchen & Bath Remodeling 3 10-24-2010 09:23 PM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 07:43 AM
Installing Bypass Shower Doors pianodude Building & Construction 2 09-08-2009 07:09 AM
Tile Baseboard on outside of plastic shower pan at linoleum joint? GaryS Tiling, ceramics, marble 2 07-26-2009 01:39 PM
Removing drain from shower tverhoef Flooring 2 03-14-2008 01:59 PM
