Removing Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-05-2007, 10:11 PM   #1
Removing Shower
I am removing the tile and replacing water-damaged walls in a small shower in my master bath, and converting it into a linen/storage closet. How do I close off the drain? I'm assuming this is a must do to prevent the possibility of drain back up and/or odor, yes?
jmnhdmil1 is offline   Reply With Quote
Old 10-06-2007, 10:07 PM   #2
Fernco qwik cap.
redline is offline   Reply With Quote
Old 10-07-2007, 06:07 AM   #3
Send a message via AIM to Marlin
If it's a perminant removal I'd cut the pipe off as far down the line as you can without disturbing another drain line and using an appropriate cap for the type of drain material. Sweat for copper, glue on for PVC, quickcap or equivalent for cast or galvanized. If you may put the shower back it's a different story.
Marlin is offline   Reply With Quote
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 02:58 PM
removing shower stall JohnH Plumbing 4 09-17-2007 03:40 PM
All shower fixtures loose, what to do? darsunt Plumbing 4 06-06-2007 12:01 PM
Bathroom Shower Help - PLEASE :) OTEJUNK Remodeling 5 05-09-2007 10:33 AM
Maxx Shower Walls Install on Metal Studs? atilla137 Plumbing 2 11-21-2006 06:17 PM
