#1 |
Removing a section of Baseboard Heat
I am doing some renovations in the kitchen and would like to remove a 5 foot section of baseboard heat. The problem is I really can not get access to the pipes from the basement. So what I was thinking of doing was cutting the pipe, above the floor, at both ends and capping them off. First, is this possible?
If not, the only other option I think I have is to again cut the pipes at each end and rerout the pipe to the other side of the wall (which is the inside of the garage. I did not know if by capping the ends I am messing up the flow of the heating system. Hopefully this made sense. |
#2 |
The water circulates through the entire loop, so no, you cannot cap them; you have to maintain the loop. Will you be installing this 5' section elsewhere in the room, or eliminating it? I do not need to know, but simply suggesting that 5' of baseboard heat is a considerable amount to eliminate, so if that is the case, you may want to reassess your options.
| Display Modes | |
| uneven heat: testing ceiling radiant heat /finding cables/fix cables | martinradiant | Electrical | 1 | 10-03-2010 09:22 PM |
| How do I bleed air from my baseboard heat / boiler | rodney23 | HVAC | 5 | 10-01-2010 11:04 PM |
| How to safely remove a section of gas baseboard in kitchen | Sephora | HVAC | 17 | 09-28-2010 05:40 PM |
| problems with finned-tube baseboard heat | rshalf | HVAC | 2 | 01-03-2010 12:10 PM |
| Heat Pump Blower always on | gg_daman | HVAC | 1 | 12-16-2009 07:15 AM |
