Removing And Re-soldering Copper Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-20-2010, 11:00 AM   #1
Rewards Points: 16
Removing and re-soldering copper fitting
Sorry for the bad terminology, but I'm a rookie. I have recently installed a 'shower only' fixture. I have the hot and cold supply lines into copper female threaded adapters (threaded into the brass fixture, and soldered on the outside). When i turned the adapters into the fixture, I only hand tightened them (i'll admit, i forgot to wrench them on). Now of course, i have a slow leak. There is teflon tape on the connection. I don't have enough room between the adapter and where it elbows downward to cut the line and solder in a coupler (after i twisted the adapter on better of course). Can I just heat the adapter up, turn it tight, and let it settle again? Or will i have to completely remove it, resand it, and resolder it? Thanks so much.
PV
PrecisionVision is offline   Reply With Quote
Old 12-20-2010, 11:19 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,060
Yes,... yer plan A, Won't work...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
PrecisionVision (12-20-2010)
Old 12-20-2010, 05:32 PM   #3
Rewards Points: 150
I get laughed at but after I clean the inside of my fitting I also take and clean the end of the fitting. If I were you I would be prepared to replace the fittings.... Sometimes it is easier to replace then reuse... Also dope it
Docwhitley is offline   Reply With Quote
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Problems removing hot water tank fitting Spastic Plumbing 2 07-17-2010 04:56 PM
Removing Water Line Obstruction Mickey53 Plumbing 11 12-15-2009 11:39 AM
Why Not Electronic Solder For Some Joints AllanJ Plumbing 16 02-08-2009 10:32 PM
removing copper caps equineman Plumbing 4 04-07-2008 10:05 PM
