Removing A Pool Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-15-2011, 05:31 PM   #1
Still Learning
Removing a pool heater
Hi all, im a journeyman plumber but never learned anything about pools. I need to remove a broken pool heater to make room for an a/c unit. Is it fine for me to connect the two pipes at the inlet and outlet of the pool heater? Is there any problem with bypassing a pool heater? Also, if i close the gate valve at the filter will that stop the flow to the heater? I dont want to open the pipes up and have a bunch of water everywhere. Thanks for the advise.
thehvacguy is offline   Reply With Quote
Old 03-15-2011, 08:25 PM   #2
HVAC / Plumbing
If you aren't going to replace it. Just cap the inlet & outlet . or, tie them together
kenmac is offline   Reply With Quote
Old 03-15-2011, 08:48 PM   #3
Still Learning
Not replacing it, its a rental. And i need the space for a condensing unit.
Old 03-16-2011, 10:33 PM   #4
Rewards Points: 150
If the pump is above the water line in the pool simply turning off the pump is all thats needed, If the equipment is below the water line you will need to shut all valves to stop the water. Generally whenever you pipe a pool you want as few elbows or extra pipe as possible but if your not being paid to repair the pool then just cut the inlet and outlet and loop them together it'll work fine.
If the heater is very old it could contain asbestos!
STL B. is offline   Reply With Quote
Old 03-16-2011, 11:29 PM   #5
Still Learning
Sweet, thats what i was hoping to do is just looping it together. I would have never have expected to find asboestes in that peice of equipment tho, thanks for the heads up. What component would contain the asboestes and how old are we talkin here?
Old 03-17-2011, 01:00 AM   #6
Rewards Points: 150
Thirty years old or older prolly older so just dont knock it around too bad
Also bring a 3/4 black iron cap just to have all your bases covered. And offer to haul it away for $40-$60 and then hack the heat exchanger out for beer money......their pretty hefty
Min distance from baseboard hotwater heater capslock General DIY Discussions 2 05-25-2010 07:31 AM
Electric Wiring for Pool Heater (heat pump) tazmajazz Electrical 7 10-21-2009 08:49 PM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
