Removing Pipe Wrap Around Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-25-2012, 02:52 PM   #1
Rewards Points: 33
Removing pipe wrap around copper pipe
I want to remove some pipe wrap around some copper pipe so I can make a cut and connect it with a sharkbite. I don't want to take a picture of it today but plan to go into the crawl space in the next few days. Believe it is wrapped around some 1/2 inch copper pipe. The pipe wrap is silver and is wrapped around the pipe to protection it from freezing. Probably was wrapped around the pipe some time between 1965 to 1980. Am I going to have trouble removing this with a box cutter or with a heavy duty scissor cutter in the picture ???? I assume it is taped to the pipe. Going to ask the clerks in the plumbing department at Home Depot what I should do. Once I get the pipe wrap off the pipe I want to get anything off the pipe, cut it, and then sand it with some steel wool. Then place the sharkbite on it. Hoping this will be easy to do.
steve3847 is offline   Reply With Quote
Old 12-25-2012, 03:46 PM   #2
Rewards Points: 700
Cut any electric power to the wrap and cut with whatever works best for you of any of a multitude of possible tools that won't damage the copper.
SeniorSitizen is offline   Reply With Quote
The Following User Says Thank You to SeniorSitizen For This Useful Post:
steve3847 (12-25-2012)
How To Bring Copper Pipe Through Concrete Block Starlight Plumbing 14 12-15-2012 08:48 AM
Septic Odor from Hole in Copper Pipe kita123 Plumbing 1 04-03-2012 09:22 PM
Copper Pipe Water Lines trophywalleye Plumbing 3 03-04-2011 09:44 PM
Removing kitchen drain pipe from wall diyrocks Plumbing 8 02-28-2011 02:37 PM
PVC air admittance value and copper waste pipe diy888 Plumbing 2 02-16-2011 08:48 AM
