Removing Pipe Wrap From 1/2 Inch Copper Pipe - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-17-2015, 04:07 PM   #1
Rewards Points: 33
Removing pipe wrap from 1/2 inch copper pipe
I'm trying to remove the pipe wrap off a 1/2 inch copper pipe. I was wondering can I torch it off with a propane torch. I will remove the wrap by hand then use the propane torch to get the rest of the pipe wrap off. Usually there is a small amount of glue left on the pipe. Just make sure I don't melt any solder joints. Then use a wash cloth and water to clean it off. Sandpaper it a little bit with 400 grid sandpaper. Then I could solder a cap or put a compression valve on the pipe. I could always call a plumber to do this. Plumber would probably charge about 200 dollars just to go into the crawlspace. Maybe I could save a couple hundred dollars. Any suggestions.
steve3847 is offline   Reply With Quote
Old 04-17-2015, 06:40 PM   #2
Rewards Points: 350
Please post a picture of the fitting steve. Thanks.
Sounds like an easy fix. No need for any blow torch. Old tape and pipe dope can be easily remove with small wire brush.
jmon is offline   Reply With Quote
The Following User Says Thank You to jmon For This Useful Post:
steve3847 (04-19-2015)
Old 04-17-2015, 06:51 PM   #3
Rewards Points: 14,306
Well that makes no since.
Is this just 1/2 foam insulation? All foam insulation has a seam.
Run your finger down the seam and it slips right off.
Why does it even need to come off?
Old 04-17-2015, 08:21 PM   #4
Rewards Points: 243
The OP might be referring to the kind of "insulation" that consists of an inch or so wide strip of 1/4" thick self adhesive foam with a foil backing. It's meant to be wrapped around the pipe like you would wrap electrical tape around a screw driver. That stuff is complete junk and I think it actually costs MORE than the foam pipe insulation. I had the same crap in my house. Scrape it off with a razor blade or similar and use a strong solvent to get the residue off. Don't burn it off with a torch. It only makes a bigger mess and kills brain cells. Ask me how I know.
chemman is offline   Reply With Quote
The Following 2 Users Say Thank You to chemman For This Useful Post:
MTN REMODEL LLC (04-17-2015), steve3847 (04-19-2015)
Old 04-17-2015, 08:32 PM   #5
Rewards Points: 6,652
Dad used to just build a fire in the backyard fire pit, and burn it off of the pipe.
The Following User Says Thank You to gregzoll For This Useful Post:
Old 04-17-2015, 08:50 PM   #6
Property Mgt/Maint
Rewards Points: 1,672
if you need to cap a open 1/2" copper pipe, clean down from the end about 3/4". Go to local big box hardware store and ask for a 1/2" gatorbite cap. Push it on and no torching in the crawlspace.
Yodaman is online now   Reply With Quote
The Following User Says Thank You to Yodaman For This Useful Post:
Old 04-18-2015, 06:09 AM   #7
An old Tradesmen
Rewards Points: 8,184
Razor blade and alcohol to clean the solvent off.
The Following User Says Thank You to beenthere For This Useful Post:
Old 04-19-2015, 08:29 AM   #8
Rewards Points: 33
I'll try and get back into the crawlspace and finish this project soon. Clean the pipe off best I can. Cap it with a sharkbite or compression valve.
Old 04-19-2015, 08:33 AM   #9
Property Mgt/Maint
if the valve ever seeps you will be fixing it again
Painted Copper Pipe Mstrlucky74 Plumbing 6 11-05-2013 05:56 AM
Grounding to cold water copper pipe joeh Electrical 2 09-12-2013 06:10 AM
Compression Valve for leaky pipe (not copper)? DIYsoon2Bpro Plumbing 11 01-18-2012 06:40 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Copper pipe size question greymous Plumbing 18 01-30-2009 04:02 PM
