Removing Pipe From Sharkbite Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-16-2015, 11:11 PM   #1
Solidify's Avatar
Rewards Points: 826
How in the heck am I supposed to get this piece of pipe out? I'm damaging the o-ring the more I try. I just cant get enough leverage. i'm tempted to solder on a length of pipe just to get a better grip but the removal tool keeps slipping off the fitting's yellow ring rather than pushing it down to release the pipe
Removing Pipe From Sharkbite Fitting-imageuploadedbydiy-chat1437106292.108086.jpg
Solidify is offline   Reply With Quote
Old 07-17-2015, 12:12 AM   #2
Water Treatment
Rewards Points: 900
You might need an extra set of hands for this.
Take a deep breath...... go slow.
Either side of the orange removal tool should work but the way you have it is the most likely.
With the valve held by some one or in a vice push the removal tool down on the plastic ring on the ball valve so that it is more into the valve body, then as that is going on with a small pair of channel locks rotate the copper pipe and while your turning pull.
The key to do all of this at the same time.
As a side note I am trying to remember the last time that I used the removal tool....... been awhile as I have been using a pair of channel locks to do the same thing.
Akpsdvan is offline   Reply With Quote
The Following User Says Thank You to Akpsdvan For This Useful Post:
Colbyt (07-17-2015)
Old 07-17-2015, 06:28 AM   #3
Solidify's Avatar
Rewards Points: 826
Ok Ak, I'll post back soon with results
Old 07-17-2015, 06:44 AM   #4
Rewards Points: 482
Attachment 174193
what you can do is get a pair of pliers and just slide them down on the yellow piece so that the metel hits the yellow and it will release, done that many times like just grip the pipe so the pliers almost grips the pipe hard enough to slip to the yellow piece and it will come off
del schisler is offline   Reply With Quote
Old 07-17-2015, 09:59 AM   #5
Solidify's Avatar
Rewards Points: 826
just tried, can't be done. gonna wait till i pass by dads this weekend since he has a vice (and i dont)
Old 07-17-2015, 11:25 AM   #6
Water Treatment
Rewards Points: 900
Did you try with the channel locks in the pipe end?
Old 07-17-2015, 12:55 PM   #7
Solidify's Avatar
Rewards Points: 826
Yea, i even tried using pliers to push the removal tool down but it really wont go down.
Old 07-17-2015, 01:19 PM   #8
Water Treatment
Rewards Points: 900
If the tan ring on the ball valve that should go down is not going down then there not much that can be done.
Old 07-17-2015, 02:22 PM   #9
Solidify's Avatar
Rewards Points: 826
You think that would be enough cause to be refunded for it?
Old 07-17-2015, 02:44 PM   #10
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
not unless they are being especially forgiving. It is likely worth a try depending on where it was purchased. if it won't go down it is likely because somebody pulled hard on the pipe and the teeth of the fitting are really embedded into the pipe and stuck. try pushing in a little on the pipe as you twist it and push on the yellow ring with whatever you want to use all at the same time.
see the teeth in there? The ring you are trying to push in simply pushes against them and cause them to be pushed outward away from the contact with the pipe. If the ring won't go in I would suspect somebody yanked on the pipe causing the teeth to get stuck in the copper.
The Following User Says Thank You to nap For This Useful Post:
ben's plumbing (07-17-2015)
Old 07-17-2015, 03:08 PM   #11
Solidify's Avatar
Rewards Points: 826
you my good friend are a genius. that worked. I guess i pulled it out too much without releasing the teeth and they dug into the pipe. when i pushed the pipe back into the valve, i saw that it moved back in quite a bit
Old 07-17-2015, 04:16 PM   #12
nap
You talking to me?
nap's Avatar
well, tell me something I don't know
glad it worked but rather than being a genius, I tend to learn from mistakes more than innate intelligence and logic. In other words; I screw up just like everybody else but now I get to come to forums like this and hopefully help those that have done similar things where I may have worked out a solution.
glad to hear it worked.
Solidify (07-17-2015)
Leaking drain pipe under kitchen sink dethun Plumbing 22 03-13-2016 05:53 AM
Question removing bathroom pipe from wall caicom98 Plumbing 11 10-21-2012 10:49 PM
Looking for 3/4" rubber tapered barbed pipe fitting for two female PVC pipes matthewadams Plumbing 14 09-11-2012 04:42 PM
Removing cut, rust old 1 1/2" steel pipe Pharmtoxboy Plumbing 5 03-11-2012 08:37 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 11:27 AM
