Removing Pex - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-19-2010, 11:19 PM   #1
Rewards Points: 16
Removing Pex
Is there a trick or tool that can remove pex tube from the fitting it is attached to?
I was installing pex with the expander tool and made a mistake. So I cut the tube close to the brass fitting and got the torch and softened the pex ring and carfully slid it off with a screwdriver. Corrected my mistake and everything went smoothly from there. But, I was thinking, if it had been one of the plastic fittings I never would have been able to torch it off. It there another way or do you just throw the fitting away in a situation like that?
HairClog is offline   Reply With Quote
Old 09-19-2010, 11:22 PM   #2
I've seen a crimp ring removal tool, but not one for uponor. My tricks for HDPE pipe are boiling water and a razor blade, I'm sure it would work for the pex too
the_man is offline   Reply With Quote
Old 09-20-2010, 11:11 AM   #3
Just call me Andrew
Rewards Points: 1,020
If you're using plastic fittings. I'd toss them. From what I understandm, once the "teeth" on the barbed fitting get nicked in any way, a leak is imminent...
Andrew
secutanudu is offline   Reply With Quote
Old 09-20-2010, 11:17 AM   #4
Civil Engineer
Rewards Points: 4,854
Same is true for brass fittings. I use the Wirsbo fittings, and I generally remove the PEX from the fitting by cutting the ring with a knife, then slitting the PEX over the fitting, then I throw out the fitting, since I almost always nick the fitting with the blade. I have been told by persons who claim to have done it that the boiling water trick works, and can allow you to slip off the PEX without damaging the fitting, but I have never successfully done it. Cheaper and faster to toss the fitting.
Removing vinyl tile (at least I think it's some sort of vinyl) natecase13 Flooring 1 07-13-2010 10:55 AM
Need Advice - Removing Bath Wall Tile Soxckersfc2002 Kitchen & Bath Remodeling 6 02-01-2010 10:49 AM
Help removing baseboards without damaging sheetrock Lighthearted Painting 3 04-05-2009 05:52 PM
removing treated lumber edging pacifier1er Landscaping & Lawn Care 3 07-02-2008 12:08 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
