Removing P Trap That Is Connected To An Overflow - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2009, 09:42 AM   #1
Removing P Trap that is connected to an overflow
I am trying to remove a P trap under a bathroom sink however it is connected via pin with no screw joint to what appears to be a separate overflow line. Any help on how to remove without cutting the pipes would be much appreciated. Picture attached:
jwwende is offline   Reply With Quote
Old 09-07-2009, 09:44 AM   #2
Remodeling Contractor
pipe is glued. You need to cut the pipe close to a fitting leaving as much pipe exposed as possible to connect again with a fernco coupling.
Old 09-07-2009, 09:48 AM   #3
Is there a specific type of glue or sealant I need to reapply to the coupling to reattach?
Old 09-07-2009, 10:25 AM   #4
the fernco is the best way to fix this. It is a rubber fitting that uses a hose clamp to fasten each end of the pipes together. Very user friendly and makes future replacements easier. Any hardware or lumber yard or box store or plumbing supply house will have them. If you want to glue new pieces together you need pvc primer and pvc glue.
Bathtub Drain -- Without Overflow Waste Trap sabinh Plumbing 6 02-15-2010 10:24 AM
Drum trap, best to replace them? diymonkey Plumbing 4 06-04-2009 08:14 AM
Cat trap fever radtek General DIY Discussions 13 05-31-2009 06:18 PM
clogged pipe or trap issue? windowguy Plumbing 3 05-10-2009 10:10 AM
Trouble removing ABS P Trap n0c7 Plumbing 12 04-06-2009 05:40 PM
