Removing Outside Water Tap - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2012, 11:26 PM   #1
Removing outside water tap
I can't seem to figure out how to remove my outside water tap. I have removed the screws holding it to the house and cut the water off to the tap. I tried to hold the pipe on the inside and turn the tap on the outside. The tap turns and the pipe inside doesn't but still the tap won't come free. This home was built in 2010, it is plastic plumbing pipe. I don't understand why the tap won't just unscrew. Is there some other way that it might be fastened? Any help would be much appreciated.
ggtg38 is offline   Reply With Quote
Old 07-25-2012, 11:35 PM   #2
Sounds like it might be pex piping. If so, you will need to cut it then possibly get a new one and refit it with a shark bite fitting with a male adaptor on one end so you can remove it again if you ever need to
jstring3 is offline   Reply With Quote
Old 07-26-2012, 05:23 PM   #3
Rewards Points: 4,792
ha ha, well if it's "plastic" piping, it's extremely unlikely that it's screwed on. Most likely it's PEX if it's plastic supply built in 2010. Assuming you have access to the source in your crawl space or basement, you just need to cut the pipe. You can Google how to reattach a new one with PEX if you're replacing it rather than just taking it out.
jeffnc is offline   Reply With Quote
Toilet flush issue. Paradiselost Plumbing 7 06-19-2012 01:47 AM
low domestic hot water flow with tankless coil mike42 HVAC 28 11-24-2011 09:35 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 11:33 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
