Old 09-17-2012, 08:34 PM   #1
Removing old tub drain
I would like to replace my rub drain strainer with a new "lift and turn".
In order to do that I need to first remove the old drain. Normally this is a simple task with a drain key grabbing onto the cross bar at the bottom and then struggle a bit with the stubborn turn.
However, mine didn't have the cross bar anymore.
Tried this tool and the friction on the sides wasn't enough to unthread it.
Then I tried this Ridgid tool and none of the "wheels" was able to fit snug to the inside of the drain to get it out. Some were too small some too large.
Didn't want to saw or cut into it for fear I might break the threads of the brass drain assembly it is threaded into.
Then I ran into this. Which is a lift and turn you can glue/epoxy into the inner surface of an existing drain basket.
Anyone used this?
Is this a good long term solution?
Or should I try to get the old basket out somehow?
What if I epoxy this drain in, will the epoxy be strong enough to unthread the old drain if I clamp onto the cross bar of this new drain with a drain key?
miamicuse is offline   Reply With Quote
Old 09-17-2012, 09:17 PM   #2
try this from lowes
http://www.lowes.com/pd_272239-943-0...sales_dollar|1
or a chisel and hammer
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
washing machine drain issues lost_punk Plumbing 2 06-19-2012 11:18 AM
Very slow drain no drain blues Plumbing 16 04-03-2012 06:39 PM
Tying into 50's style clay drain tile perimiter system/exposed Pit / Wall membrane alecmcmahon Plumbing 6 12-29-2010 08:23 AM
Bathtub Drain Leak Help! jgcable Plumbing 54 12-19-2010 11:40 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 03:25 AM
