Removing Old Stopper Assembly - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-06-2010, 03:48 PM   #1
Removing old stopper assembly
Our old push/step on stopper broke in our bathtub. I went to the hardware store and bought a new assembly. We cannot turn the old assembly to get it out. We put WD-40 around the drain inside and on the outside. It won't budge. How can we get it out?
cypress2009 is offline   Reply With Quote
Old 03-06-2010, 07:25 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
There are quite a few different styles... maybe a picture would help here.
Journeyman Plumber
Old 03-06-2010, 09:21 PM   #3
DIY staff
Rewards Points: 7,174
Most have a brass or plastic nut under the sink,back that nut down as far as you can.
loosen up the rubber washer and push up on the assembly.
Grab the decorative chrome ring in the sink bowl and unscrew that from the lower piece and you should be ready to install the new one.
If the brass nut is permanently corroded to the assembly--carefully drill a notch into the nut and split the nut off with a screw driver.--Mike--
The new one could give you a clue as to how the old one is built--It would be handy if the old and new are similar.
Old 03-07-2010, 12:43 PM   #4
Doing it myself
Alan's Avatar
He said in his bathtub.
Journeyman Plumber
Old 03-07-2010, 01:24 PM   #5
DIY staff
OOPS!--He has also disappeared--There are several different pop ups on tubs. Tough to help on that one---
jammed Brass overflow stopper Raouf Plumbing 1 11-14-2009 07:11 AM
adding new sink / faucet / drain assembly... and I'm clueless :-( diy'er on LI Plumbing 4 11-13-2009 06:36 PM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 08:31 AM
pedestal sink drain stopper not working gernith Plumbing 7 04-18-2008 10:17 PM
Price pfister tub stopper problem rocboz Plumbing 2 11-18-2007 05:35 PM
