Removing Old Radiator - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-03-2011, 08:29 PM   #1
removing old radiator
This radiator is no longer working, it's part of an old heating system that no longer exists. I want to remove it while I'm renovating my bathroom.
I had no luck with my wrench's trying to turn the fittings, any tips for getting this out of the bathroom? I have a sledge hammer but wanted to cause as little damage as possible
- Jonathan
jthn is offline   Reply With Quote
Old 01-03-2011, 08:46 PM   #2
Rewards Points: 252
Get out the sledge and a 4-1/2 in. die grinder with a metal cut off disk. You have a cast iron radiator cemented into the wall. By itself IT IS HEAVY !!!! Whoever installed it put it in on the "cheap" without any radiator unions. so you cannot remove it without destroying the radiator and/or the wall. There may actually be one on the shutoff valve where it goes to the floor -maybe-, but you need 3 or four inches all around it to get an 18 on it and torque it off.
Grampa Bud is offline   Reply With Quote
Old 01-03-2011, 09:13 PM   #3
Thanks, I'll use the grinder and sledge combo as you suggest.
Hot water radiator relocation issues... Timmy_LI Plumbing 0 12-16-2010 05:35 PM
Steam Radiator in Hot Water System whitesjtaa HVAC 4 01-11-2010 08:32 PM
Removing a Cast Iron Radiator MugsynSax Plumbing 1 10-05-2009 04:18 PM
Monoflow sytem Q's and adding a radiator jaytech33 HVAC 1 08-23-2009 06:10 PM
removing a radiator? babyt8988 Appliances 4 03-04-2009 09:00 PM
