Removing An Old Lav Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2011, 03:12 PM   #1
Removing an old lav faucet
I've done this before, but I've never run into this problem. I'm attempting to remove an old widespread lav faucet, but try as I may, I cannot get either the handles or faucet out. Usually there is a plastic washer that holds the pieces in place, but this is all brass. Everything is loose, but I can't get eh pieces above and below the sink to separate. I've even removed the sink for better access, but nothing...HELP!
BequiaT is offline   Reply With Quote
Old 04-09-2011, 03:41 PM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
Have you removed the hot/cold handles as well?
Photos always help us help you.
DM
Old 04-09-2011, 04:06 PM   #3
Follow-up
Hi Danger Mouse,
Can't remove the faucet, taps or drain, and my photos are too big to upload.
Old 04-09-2011, 04:14 PM   #4
Figured it out - photo attached
Hi,
This photo should show you what I'm working with
Old 04-09-2011, 07:58 PM   #5
DIY staff
Rewards Points: 7,174
Those remove from the top----the nuts showing in the picture are used to adjust the height of the faucet.
Remove the handles-( usually a screw under a little cap or an Allen set on the side)
Unscrew the Escutcheon under the handle and you will find the top nut that holds that valve body in place.----Mike---
Removing supply lines from bath faucet Rilgen Plumbing 8 02-18-2011 09:31 AM
removing very old kitchen faucet. Eric Maurer Plumbing 3 02-13-2011 02:21 PM
Need help removing Delta bathroom faucet Mr_allthumbs Plumbing 6 06-01-2010 05:50 PM
Trouble removing kitchen faucet rebeccac Plumbing 12 11-29-2009 12:51 PM
Trouble removing old kitchen faucet vikinghelmet Plumbing 1 08-18-2008 03:02 PM
