Removing Kitchen Faucet - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-06-2012, 08:57 PM   #1
Can someone please advise me on the best way to remove this kitchen faucet? It seems like the nut at the bottom of the plate is attached to the plate.
Removing Kitchen Faucet-20120506_205351.jpg   Removing Kitchen Faucet-20120506_205441.jpg
Todd54 is offline   Reply With Quote
Old 05-06-2012, 08:58 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
It's not attached, just corroded.
Are you replacing the faucet? If so you can usually cut that nut off with a dremel tool.
If you're just trying to make a repair, that should be able to be accomplished from above.
Journeyman Plumber
Old 05-06-2012, 09:06 PM   #3
I'm replacing the faucet. I think I need a basin wrench and don't have one right now.
Old 05-07-2012, 07:22 AM   #4
Rewards Points: 1,644
Get a small adjustable wrench and remove the nut or cut it off with a dremel-like tool.
bob22 is offline   Reply With Quote
Old 05-07-2012, 09:14 AM   #5
Doing it myself
Alan's Avatar
most of the time a basin wrench won't get those anyway because they are too small and crowded by the supply lines. They usually give a special tool for those
faucets. It's basically an extra deep socket made from plastic.
I've also had to disassemble faucets from the top of the counter before and cut the shank from above because the nut was so badly corroded together that I couldn't get a tool on them.
Journeyman Plumber
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 08:45 AM
Good brand of kitchen faucet for an old home Stevoreno Plumbing 17 05-23-2010 06:33 PM
Kitchen Faucet + shower diverter: Need help xtrips Plumbing 1 02-14-2010 03:27 PM
Low hot water pressure on kitchen faucet Ultrarunner2017 Plumbing 7 12-19-2008 09:49 AM
Question about a kitchen faucet skwpt Plumbing 10 10-11-2007 06:54 PM
