Removing Kitchen Drain Pipe From Wall - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-12-2011, 05:12 PM   #1
Removing kitchen drain pipe from wall
The metal nut that connects the kitchen drain pipe has cracked and is leaking. I can't remove the drain pipe from the wall so I can slide a new nut over the pipe. It seems to have a plastic washer firmly wedged in there or maybe it's rusted together. I've tried to turn the bare pipe with a pipe wrench to loosen it up but the wrench won't grip the bare pipe. What should I do?
Removing kitchen drain pipe from wall-pipe1.jpg   Removing kitchen drain pipe from wall-pipe2.jpg
diyrocks is offline   Reply With Quote
Old 02-12-2011, 05:48 PM   #2
Okay, I would cut the brass trap arm even with the end of the steel pipe sticking out of the wall, and get a "fernco" adapter-1 1/2" pipe size x 1 1/2" outside diameter tubing and use that to connect the two.
broox is offline   Reply With Quote
Old 02-12-2011, 06:50 PM   #3
Are you thinking I shouldn't try to pull the trap arm out of the wall because I could cause a leak behind the wall? I'm on the third floor in an apartment building.
How would you cut the trap arm? I'd really rather not do that though since I'm renting. Can I connect a Fernco adapter below the trap arm "lip"?
Any other options?
Old 02-12-2011, 06:58 PM   #4
Rewards Points: 1,578
Why are you fixing the landlord's property? Get him/her to do it. If you screw it up and cause damage, you'll be liable to fix it (think water on the 2nd floor tenant's ceiling).
bob22 is offline   Reply With Quote
Old 02-12-2011, 07:29 PM   #5
DIY staff
Rewards Points: 7,174
That old chrome trap arm is just rusted into the iron pipe----wedge a screwdriver between the chrome tube and the iron pipe--It will crush--then pry the crushed tube out of there---Done.--Mike---
Old 02-12-2011, 07:47 PM   #6
I would be careful with that old galvanized stub out. I have seen them get very thin and brittle, so I would not get too rough with it. And why are you fixing your landlords stuff????
Old 02-22-2011, 10:51 PM   #7
I'd like to fix it myself if I can.
Do you think crushing the chrome trap arm with a screwdriver is likely to cause a problem further down the pipe inside the wall?
After crushing the trap arm, won't the threads of the pipe that goes inside the wall be unable to accept a new threaded trap arm since they're rusty?
Old 02-23-2011, 05:26 AM   #8
DIY staff
You will be able to scrape out enough rust and crud to get a new PVC trap arm into that nipple---
That trap arm only goes into the nipple an inch or so if it was installed correctly--It's very thin brass and very corroded--Try it---you are overly worried about this---Mike---
Old 02-28-2011, 01:37 PM   #9
It was even easier than I expected. I just needed to pry that plastic washer out and the pipe slid out no problem. Thanks everyone!
lowering iron sink drain in kitchen wall leeb Plumbing 2 07-09-2010 09:11 AM
Slow kitchen drain - tried almost everything! Critical Mass Plumbing 17 07-15-2009 07:57 AM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 05:46 PM
Kitchen drain pipe after P-trap goes UP?? pcampbell Plumbing 19 11-09-2008 03:14 PM
Building a soffit around a drainage pipe along the wall ssudha17 Building & Construction 12 10-04-2008 03:18 PM
