Old 03-26-2011, 11:12 PM   #1
removing iron drain from foundation
hi,
I'm in process remodeling the bathroom in a guest cottage. As part of the remodel, I'm moving the toilet, sink and shower. based on the way that the current drains are set up (not in the right spots), I think that the best thing to do is to cut the drain at the entry to the building, and rebuild the drain system new (using plastic) and hook the new to the old with one of the rubber sleeve adapters. I have two options where to do this.
1. cut the drain just on the inside of the foundation. there is very little working space there (see the photos) because the first joint (a Y going to the main stack and toilet) is tight almost up against the foundation. I think that I should be able to make the cut, but I'm concerned about being able to see well enough and work well enough to get the transition done well (never done one before)
2. cut the drain outside the foundation. this should offer plenty of working space, and I already dug the hole, but I'm a little nervous about getting the old pipe out of the foundation. I was able to clear holes on the two sides of the drain, but there appears to be concrete both on top of and below the drain. without cutting it, I don't really have a way to tell how rigidly attached to the foundation it is.
based on all this, I've got a couple of questions:
- where should I cut the drain?
- what's the preferred cutting method (I've heard sawzall and special pipe cracking tools can work)
- any other tips?
thanks in advance
removing iron drain from foundation-img_0261.jpg   removing iron drain from foundation-img_0262.jpg   removing iron drain from foundation-img_0263.jpg
osmotik is offline   Reply With Quote
Old 03-27-2011, 07:43 AM   #2
Super Moderator
I think I'd cut it out side----Actually make two cuts---
Rent a chain breaker (sometimes called a cracker or popper)
Break it about 12" from the foundation---an again about 3 or 4 feet from the foundation.
Remove the section----now you have room to swing a sledge hammer--tap the pipe into the crawl enough to get your breaker onto the inside pipe---
Break off the fittings inside--wiggle the pipe out of the foundation.----Mike---(good pictures!)
Old 03-27-2011, 08:46 AM   #3
Plumb or Die!
Chain cutters outside the building or a grinder with a zip cut wheel, or a big gas cut off saw. Take a sledgehammer to the rest of it.
plumber666 is offline   Reply With Quote
Old 03-27-2011, 11:35 AM   #4
thanks, i was thinking outside would be easier too. the second cut makes a lot of sense to get some swing room for a sledge. Are the transition fittings rated for direct burial, or do I need to install a box around it?
Old 03-27-2011, 11:38 AM   #5
one thing to add... you'll probably need a rotohammer to enlarge the hole thru the foundation for ABS/PVC pipe, the outside diameter on plastic pipe is larger than the cast iron. seal the hole thru the foundation with mortar when you're done, and maybe think about an outside cleanout for the sewer while you're at it
the_man is offline   Reply With Quote
The Following 2 Users Say Thank You to the_man For This Useful Post:
LateralConcepts (04-04-2011), oh'mike (03-27-2011)
Old 03-27-2011, 12:57 PM   #6
With regards to the pipe size, it's currently 4" for the buried section and continues to 4" inside the building for the main stack. The drain serves a toilet, sink and shower, which I believe only requires 3". Would it be appropriate to transition to 3" outside the building? The would make it easier to thread through the foundation, and also would give me a little more space to run the necessary fittings once I am inside the building.
Old 03-27-2011, 01:31 PM   #7
Super Moderator
You will be fine with 3"---Make the transition outside---Mike---
Old 03-27-2011, 02:00 PM   #8
3" is adequate for the size of the drain, however some municipalities require a 4" building drain before the pipe exits the foundation. shouldn't matter for functionality, but if a permit is pulled or inspection done after the fact it could be an issue
The Following User Says Thank You to the_man For This Useful Post:
Old 03-27-2011, 02:34 PM   #9
Just want to re-post one question that got buried by the other posts. Are the transitions from cast iron to PVC rated for direct burial, or should I install a box?
Old 03-27-2011, 02:51 PM   #10
ferncos and stainless steel nohubs are rated for direct burial. if you use a nohub coupling, make sure it's sized for CIxPlastic
Old 03-27-2011, 03:05 PM   #11
Thanks for all the help. I will check on the local code requirements, but will aim to transition from the 4" iron to 3" PVC outside the building, then will have a clean 3" PVC to work with once I'm inside.
The Following User Says Thank You to osmotik For This Useful Post:
Old 03-28-2011, 08:28 AM   #12
Plumb or Die!
If you ever plan on adding any plumbing to the house in the future, I'd leave it 4". The code I work with only allows one toilet on a 3" line, and any building drain must be 4" or larger. The diameter difference between PVC/ABS and cast iron is minor. Like a 1/8" or less. Always better to oversize than undersize.
Old 03-28-2011, 01:30 PM   #13
interesting point. in this case, the building is a garage/in-law suite, so unlikely that I would add another toilet. but I guess if 4" is doable, no reason not to have it.
Old 04-04-2011, 01:05 AM   #14
I rented a snap cutter today and was able to remove all the DWV pipes both inside the bathroom and the one pictured. Thanks for the good ideas. The snap cutter worked great, but man was the 4" vent stack heavy! The only advice I'd give anyone setting off on the same task is to think ahead about the order you make your cuts, the snap cutter puts a lot of torque on the pipe, so I think it's best to start cutting at the vents out the roof or the fixtures so that things aren't twisting around on you a lot (I did the opposite leaving a 8ft straight section of vent till the end which I couldn't keep from spinning, so had to pull it out of the roof in one piece,)
Old 04-04-2011, 08:24 AM   #15
Plumb or Die!
Good on ya for going for it!
four inch plastic drain pipe through concrete foundation wall dan patterson Plumbing 11 01-25-2011 07:23 AM
floor drain / cast iron to pvc? n2learning Plumbing 3 08-01-2010 07:20 PM
Replace tub's drain ring without removing tub? BradG Plumbing 12 03-17-2009 12:21 PM
Cutting Iron Drain Pipe jonathan03 Plumbing 12 01-31-2009 10:33 PM
Removing drain from shower tverhoef Flooring 2 03-14-2008 01:59 PM
