Removing Gatorbite Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-21-2011, 01:25 PM   #1
Rewards Points: 77
used a gatorbite fitting in a super tight spot even though even instinct said these suck and naturally i was right, its leaking now, it says permanent on the package and i have found online "removable gatorbite fittings", this isnt one of them of course......anyone got any ideas or tips before i use a vise grip and a hammer?
bryan1282 is offline   Reply With Quote
Old 08-21-2011, 01:35 PM   #2
if its one of the copper colored ones then its not removable and you're best off just to cut it out. a hammer and vice grips will damage the pipe so you cannot reseal it.
the_man is offline   Reply With Quote
Old 08-21-2011, 02:09 PM   #3
Rewards Points: 77
yeah thats what it is, what a stupid idea that was, im gonna try to solder an elbow to it now, i only have 1 inch of pipe sticking out of the floor after cutting it out to work with so this is my last shot, wish me luck, lol.
Old 09-19-2011, 01:01 PM   #4
actually I think they make a tool to remove the cheap Gatorbite.
I saw it at Lowe's but did not look carefully.
I believe it is just a ring that release the teeth so u can slide the pipe out.
probably can make one with a piece of alum flashing.
ruggb is offline   Reply With Quote
Copper Y fitting and cabinet install brneilly Plumbing 4 06-30-2011 09:13 AM
gatorbite copper pipe fitting granof8 Plumbing 6 01-18-2011 05:19 PM
Removing and re-soldering copper fitting PrecisionVision Plumbing 2 12-20-2010 05:32 PM
Problems removing hot water tank fitting Spastic Plumbing 2 07-17-2010 04:56 PM
How to reuse a ABS fitting guide n0c7 Plumbing 4 08-27-2008 05:30 PM
