Removing a "Flush Valve" (no tank) toilet
I am assuming "the first valve" you ars talking about is the angle stop coming out of the wall(or floor) with a supply line going to the toilet. If that is what you are talking about, then just shut it off, flush the toilet. disconnect line, check for leaks (they are notorious for leaking) remove the rest of the water from toilet, and remove toilet
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
