Old 06-03-2008, 01:28 PM   #1
Removing floor drain
I am removing an old stand-up shower and making it into a closet. Can I just use a Fernco to cap the old drain or is there some other way to cap the drain pipe? I'm going to have to cut it off level to the floor and it's cast iron. Any suggestions???
Thanks,
J
luv2plumb is offline   Reply With Quote
Old 06-03-2008, 05:37 PM   #2
Building and plumbing
USP45's Avatar
Fernco cap
USP45 is offline   Reply With Quote
Removing compression ring? ruzz Plumbing 30 10-01-2011 07:14 PM
Removing wooden line posts from ground bigolepaul General Discussion 3 05-21-2008 07:20 AM
removing blown in insulation brownerd HVAC 2 08-09-2006 12:53 PM
removing knockdown texture K_I37 Painting 7 05-07-2006 02:23 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 10:28 AM
