Removing Delta Roman Tub Spout - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-31-2010, 01:34 PM   #1
Unhappy
I have a 24 year old Delta roman tub faucet assembly. No problem removing the faucets and faucet trim, but I cannot remove the 11" long SPOUT. It does NOT have a set screw in the back. Appears to be older than the Model 2710. I have disassembled the spout and it has a bracket inside that appears to be fastened from underneath to the tub deck at the rear of the spout. I now fear I will need to tear the entire tub surround apart to get underneath the tub deck to remove this obsolete spout. Any ideas out there?
stanart is offline   Reply With Quote
Old 10-31-2010, 06:20 PM   #2
Rewards Points: 150
Without knowing exactly what you have I can only go by Deltas' home site and they are mostly fastened from the bottom, sorry.
braindead is offline   Reply With Quote
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 05:02 PM
Delta tub spout question natwin Plumbing 19 02-17-2013 02:23 PM
removing Delta 1400 cartridge toe-fu Plumbing 1 09-24-2009 11:54 AM
Difficulty removing tub spout RobMart Plumbing 2 05-20-2009 09:32 AM
Removing tub spout dummy14 Plumbing 20 11-17-2008 12:48 PM
