Removing Delta 1400 Cartridge - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-23-2009, 05:51 PM   #1
removing Delta 1400 cartridge
Hey guys, I'm having an extremely difficult time removing the cartridge out of my Delta 1400 shower faucet. I removed the brass collar from the housing. I spoke with a plumber over the phone and he said that the cartridge should just pull out. I've also been all over the internet and they say the same thing, that the valve should just pull out. My valve will not pull out. I've been pulling and twisting for and hour and a half and it's still stuck in there. Could someone please give any advice, as I will be without water until I get this figured out. (a maybe on the brink of divorce when my wife gets home) thanks.
toe-fu is offline   Reply With Quote
Old 09-24-2009, 11:54 AM   #2
Home Remodeler
Rewards Points: 164
So are you saying the brass collar is the threaded nut?
mikey48 is offline   Reply With Quote
Problem removing handle off of Delta Monitor 1400 series tub/shower faucet kcinsj Plumbing 35 10-22-2015 05:02 PM
Need help: Broken stem in Moen shower faucet valve cartridge Learning Lots Plumbing 14 04-06-2015 06:27 PM
New Moen Cartridge leaks Firemanjl Plumbing 4 07-21-2011 11:53 AM
Need help fixing leak to Delta Monitor 1400 series shower/tub faucet star987 Plumbing 16 05-01-2011 06:26 PM
delta 1400 series wrbdiy Plumbing 2 01-18-2009 12:56 PM
