Old 03-10-2012, 07:21 PM   #1
Angry
Removing cut, rust old 1 1/2" steel pipe
Alright, got a tough one for ya. I am trying to remove a steel pipe that has been cut and there is not much left. It is a drain pipe, and there is clearly some rust. Also, the wood beam to the basement roof is right next to it, so access on the one side is completely blocked. I can't really use a pipe wrench, because it keeps slipping because the pipe has been cut and there is not too much to grip. Any thoughts?
Removing cut, rust old 1 1/2" steel pipe-photo-5-.jpg
Pharmtoxboy is offline   Reply With Quote
Old 03-10-2012, 07:41 PM   #2
GC/Master Plumber/Mech
If it was me I would cut the nipple off flush and use a chisel to remove the rest of the threads.
Just go slow and you will be fine.
The other thing you might try first is use a torch and heat the hub and then try and remove the damaged nipple.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
The Following User Says Thank You to Plumber101 For This Useful Post:
plummen (03-11-2012)
Old 03-10-2012, 10:04 PM   #3
Sawsall flush and then inside pipe a few time just short of the threads. Small chesle and a screw driver.
Hardway is offline   Reply With Quote
Old 03-10-2012, 10:18 PM   #4
Cut the whole thing out and replace it it all with PVC. It's going to leak at some point anyway.
Old 03-11-2012, 09:29 AM   #5
the pipe that the nipple goes into look pretty thick to me are you sure it is not going into cast iron and is leaded in place
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is offline   Reply With Quote
Old 03-11-2012, 09:37 AM   #6
Master Plumber
Javiles's Avatar
I think Joe must own a pvc pipe factory somewhere
Experience is Knowing what to do next, Skill is knowing how to do it
Javiles is offline   Reply With Quote
Tags
rusted pipe
old steel pipe buddy hathorn Plumbing 7 03-08-2012 11:16 PM
Can I use steel pipe for the oil line to the furnace? tractorfarmer HVAC 18 01-19-2012 03:56 AM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
1/2" pipe fittings don't fit old pipe- PLEASE HELP carjack Plumbing 1 05-21-2009 04:22 AM
Removing dents from stainless steel refrigerator tripower Appliances 4 02-27-2009 06:47 AM
