-   -   Removing cut, rust old 1 1/2" steel pipe (http://www.diychatroom.com/f7/removing-cut-rust-old-1-1-2-steel-pipe-136633/)
Pharmtoxboy 03-10-2012 07:21 PM
1 Attachment(s)
Alright, got a tough one for ya. I am trying to remove a steel pipe that has been cut and there is not much left. It is a drain pipe, and there is clearly some rust. Also, the wood beam to the basement roof is right next to it, so access on the one side is completely blocked. I can't really use a pipe wrench, because it keeps slipping because the pipe has been cut and there is not too much to grip. Any thoughts?
Plumber101 03-10-2012 07:41 PM
If it was me I would cut the nipple off flush and use a chisel to remove the rest of the threads.
Just go slow and you will be fine.
The other thing you might try first is use a torch and heat the hub and then try and remove the damaged nipple.
Hardway 03-10-2012 10:04 PM
Sawsall flush and then inside pipe a few time just short of the threads. Small chesle and a screw driver.
joecaption 03-10-2012 10:18 PM
Cut the whole thing out and replace it it all with PVC. It's going to leak at some point anyway.
jaydevries 03-11-2012 09:29 AM
the pipe that the nipple goes into look pretty thick to me are you sure it is not going into cast iron and is leaded in place
Javiles 03-11-2012 09:37 AM
I think Joe must own a pvc pipe factory somewhere :laughing:
