Removing Copper Caps - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-03-2008, 10:47 AM   #1
removing copper caps
I had pipes burst during the winter in my barn. So, I sweated a cap onto the existing pipe untill a better time came when I could do the repairs. Now that I am ready, I don't have enough of the existing pipe to cut below the cap. My plan is to remove the cap from the existing pipe. Can this be done? I am heating the cap and trying to pull it off, but it is a little bit stubborn and not coming off. And then I was thinking if I can couple to that end once the cap is off?
equineman is offline   Reply With Quote
Old 04-03-2008, 10:55 AM   #2
Mold!! Let's kill it!
Rewards Points: 2,012
Drill a hole in the end of the cap. There may be water laying in it that's sucking away all of your heat. After you unsolder the cap you should be able to sweat on another fitting.
Old 04-03-2008, 12:24 PM   #3
Building and plumbing
USP45's Avatar
Rewards Points: 150
Exactly. Drill the hole near the bottom of the cap.
USP45 is offline   Reply With Quote
Old 04-05-2008, 11:56 AM   #4
Try putting a screw (sheetrock type) in the hole. As you heat the cap, take a pliers and pull it off with the screw. It'll keep the cap from squishing the pipe and cause more problems.
Fitter is offline   Reply With Quote
Old 04-07-2008, 11:05 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
The other possibility is that you're overheating it.... the pipe is expanding inside the fitting and it's too tight to pull off..... You can tell if you're up to temp by brushing a little flux on it..... if it sizzles, you're plenty hot, if not you may be having the water issue as described above. Can't you just cut it?
Journeyman Plumber
PEX vs. Copper Aglease Plumbing 41 02-16-2010 06:14 AM
Copper bond epoxy rjniles Plumbing 6 03-08-2008 10:21 AM
brass trap to copper drain? bluebee1314 Plumbing 3 04-02-2007 11:29 PM
Questions about copper tubing... SDeeter19464 Plumbing 3 04-21-2006 09:11 AM
Copper Hot Water Tank - Green Stain grover432 Plumbing 2 11-29-2005 12:05 AM
