Removing Compression Ring? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-01-2011, 06:14 PM   #31
DIY staff
Rewards Points: 7,174
Rarely --but often enough to note: Not all shutoff valves have the same depth socket for the pipe--
Some times the ferrel is to far back (leavibg the copper to long) to fit into a Brass Craft shut off.
Three solutions---Get a shut off with a deeper throat-(Lowe's shut offs are deeper I think)
Cut off 1/8 of an inch of copper (I have a tiny 'Imp' cutter that will do that)
Cut the pipe behind the ferrel and use a new one.
Which is better? WAX or Non-Wax toilet ring? KUIPORNG Plumbing 16 08-27-2016 11:52 PM
removing blown in insulation brownerd HVAC 2 08-09-2006 11:53 AM
removing knockdown texture K_I37 Painting 7 05-07-2006 01:23 PM
closet flange wax ring problem elkmo Plumbing 2 01-14-2006 02:30 PM
removing OSB Underlay?? maikenh Flooring 1 12-23-2005 09:28 AM
