Removing Cleanout Plug (Emergency) - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-27-2011, 06:50 PM   #1
harry_ho's Avatar
Removing cleanout plug (Emergency)
This cleanout plug is stuck. REAL good.
I don't know what material this is, but it's pretty soft. Maybe lead? I sprayed some nut buster in the threads and tried turning it with my pipe wrench, but couldn't get a good bite. Also tried beating it loose with a cold chisel and two-pound hammer with no luck.
Any advice will be much appreciated.
harry_ho is offline   Reply With Quote
Old 10-27-2011, 06:56 PM   #2
harry_ho's Avatar
Oh, yeah...the emergency is that the line is clogged. Packed solid, I think. I've got nothing going down right now. At some point while I was at work today, the sewage backed into an upstream toilet and started dribbling down into my basement. I'm trying to get in there to snake it clear.
Also, I checked the upstream cleanouts, and they were clear as far as I could see down the drain line. There was a shallow buildup of soggy solids, though.
Old 10-27-2011, 07:19 PM   #3
biggles's Avatar
24"pipe wrench and a piece of pipe slipped onto the handle as purswaidder be careful that looks like cast and hammering it did you thy the reducer fitting the plug goes into that goes into the actual T-Y
Old 10-27-2011, 07:22 PM   #4
harry_ho's Avatar
The thing is, somebody (before me) hammered on it, too, and that square protrusion where your wrench bites is sunk down a bit. I could only get about a quarter-inch bite, and it just goobered up the material when I torqued on it.
Old 10-27-2011, 07:47 PM   #5
harry_ho's Avatar
Ummm, I think it's leaded and oakumed in. Maybe. The only thing I know about working cast iron is installing Fercos.
I was thinking I might have to just bust that plug out of there (gently), snake, clean up the female threads, and install a new plug, but the one in there seems to be an odd size. Measures 2-13/16" across to the outside of the threads. That doesn't match my 2" or 3" plugs in my plumbing box. Do 2-1/2" inch plugs exist?
Old 10-27-2011, 08:10 PM   #6
biggles's Avatar
no outside vent before it hits the street and a butane torch on the cap to heat it up a little..looks like threaded in on both plug and Y adapter can you get a wrench on that adapter into the Y
Old 10-27-2011, 08:13 PM   #7
harry_ho's Avatar
I'll give it a shot. Thanks for helping me out on this, buddy.
Old 10-27-2011, 09:15 PM   #8
biggles's Avatar
no problem but monstor pipe wrenchs on the Y and that adapter would do it that brass square on the plug should of been tefloned in and a 1/2 turn tight isn't going to take much more grabbing...good luck.like you thought drill out the plug and cut the pieces out saving that adaper into the Y
Old 10-27-2011, 10:09 PM   #9
harry_ho's Avatar
Phew! So, I had to use my cold chisel some more to remove that old brass plug, and had my brother bring one of those expanding rubber test plugs. Of course, it didn't fit, but I modified it with the belt sander and made it work. I'm going to try the plumbing house tomorrow for a better replacement.
Anyway, here's what I found with the plug knocked out:
Not a great picture, but there is only about a one-inch slit still open in the pipe. Hitting it with the water hose sprayer had no effect, and I'm pretty sure my cheap, non-powered snake won't be able to clear it either.
So, what's going on in this pipe anyway? This doesn't look (to me) like stuff that went down the toilet. I'm assuming that I'll have to call in a pro on this one if I ever get some money.
Old 10-27-2011, 10:10 PM   #10
Plumber
TheEplumber's Avatar
Rewards Points: 814
The easiest way to remove it is to use a cold chisel. Beat a hole near the center of it and use channel locks to pry it out. It is brass and should be pretty thin. Takes longer to gather the tools then to remove it. Buy a new plastic plug as a replacement. Oh, and be ready for a cleanup job. Might consider pulling the toilet and cabling through the flange
Old 10-27-2011, 10:14 PM   #11
harry_ho's Avatar
Ha! I had a five-gallon bucket ready!
This cleanout is for where the line exits the house. Everything upstream is okay. Unless the wife starts flushing toilets some more.
Old 10-27-2011, 10:34 PM   #12
Plumber
Rewards Points: 814
You might consider renting a cable machine if money is tight but a pro is probably the best route. Looks like you have a blockage downstream. Perhaps roots. Consider having the line video inspected too. It will show you whats wrong.
The Following User Says Thank You to TheEplumber For This Useful Post:
harry_ho (10-27-2011)
Old 10-27-2011, 10:51 PM   #13
harry_ho's Avatar
Thanks for the advice, fellas. I'm thinking that trying to clear this line myself really will be a big waste of time and money. I'll get my plumber out here.
I'll try to remember to update this when I find out what's going on.
Old 10-28-2011, 04:27 AM   #14
DIY staff
Rewards Points: 7,174
Fish that old hinge out of the pipe before you push it down stream--
--how do you suppose a hinge go in there?
Old 10-28-2011, 07:37 AM   #15
harry_ho's Avatar
Looks like work is rained out today.
I attacked that sewer line with a piece of rebar and managed to clear out about five feet of it. Up to the point of a quarter bend. Still plugged downstream of there, though. Also shoved my cheap little fifteen-foot snake in there, but didn't hit anything. The county boys are supposed to be out sometime today to check out their end. Maybe bring some good news with 'em.
I pulled it out for ya...wasn't a hinge, though. Don't know how I'd have explained that. Looked like the lens from a pair of sunglasses. Actually, I can't explain that one, either.
Sewer cleanout - which side of trap? Ultrarunner2017 Plumbing 4 08-29-2011 08:56 AM
Re-using a drain cleanout mpt1123 Plumbing 0 01-19-2010 05:45 AM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 01:17 PM
Aux and Emergency CPH settings indvid HVAC 2 03-02-2009 03:31 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 08:07 PM
