Old 04-21-2012, 04:41 PM   #1
Removing caulk from newer tub
I need to remove caulk from a newer style tub surround and was going to use Dap caulk be gone (if I can find the stuff) to do it. Will this product damage the finish on this type of tub? The caulk isn't located on a ledge, it's under a 'lip' so it will drip down the tub. I don't want to use a razor, either,....can anyone recommend a tool that I could use that won't scratch the surface? I was also going to use Kwik seal 3 so that the tub can be used in a short period of time after it's done. Any recommendations or advice?
Non-handyman forever is offline   Reply With Quote
Old 04-22-2012, 09:26 AM   #2
post a pic/s
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
removing tub door track that has silicone caulk W. Flink Kitchen & Bath Remodeling 1 03-13-2011 02:10 PM
removing newer paint from coke machine lucky1 Painting 7 03-06-2011 09:17 AM
Removing caulk? ysrchris Carpentry 8 03-05-2011 10:53 PM
How to seal my attic access - airtight? akoch General Discussion 4 09-08-2008 09:03 PM
Removing caulk from paint n0c7 Flooring 1 09-07-2008 12:28 PM
