Removing Cast Iron Wye Joint - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-25-2010, 12:59 AM   #1
removing cast iron wye joint
I have a major blockage in my old cast iron drain pipe...I`m looking to cut out the wye joint along with the vent cross section,the cast iron measures 2-1/2 inch`s.... I was wondering if I can reduce it down to 1-1/2 PVC...
diy718 is offline   Reply With Quote
Old 10-25-2010, 05:36 AM   #2
DIY staff
Rewards Points: 7,174
A picture is needed-----If it is cast iron,not threaded steel, you can rent a chain breaker at any rental store--that will pop the pipe quickly.
Use rubber Fernco type fittings to add your new pvc pipe.
Pictures if you can--Mike--
diy718 (10-25-2010)
Old 10-25-2010, 11:32 AM   #3
My question was is the reduction in size ok?
Old 10-25-2010, 04:51 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,358
Ayuh,... What's it draining,..?? 1, 1/2" is pretty small...
Bondo is online now   Reply With Quote
The Following User Says Thank You to Bondo For This Useful Post:
diy718 (10-25-2010)
Old 10-25-2010, 05:19 PM   #5
Rewards Points: 150
Without knowing what it's connected to the answer is NO.
braindead is offline   Reply With Quote
The Following User Says Thank You to braindead For This Useful Post:
diy718 (10-25-2010)
Old 10-25-2010, 05:32 PM   #6
DIY staff
Same answer---a restriction in a drain should be avoided.
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
removing rust from a vintage painted cast iron doorstop Margo Painting 6 03-08-2011 03:22 PM
Joining ABS to cast iron at a joint tns1 Plumbing 9 06-21-2010 01:05 PM
Removing a Cast Iron Radiator MugsynSax Plumbing 1 10-05-2009 04:18 PM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
