-   -   removing cast iron wye joint (http://www.diychatroom.com/f7/removing-cast-iron-wye-joint-84821/)
diy718 10-25-2010 12:59 AM
I have a major blockage in my old cast iron drain pipe...I`m looking to cut out the wye joint along with the vent cross section,the cast iron measures 2-1/2 inch`s.... I was wondering if I can reduce it down to 1-1/2 PVC...
oh'mike 10-25-2010 05:36 AM
A picture is needed-----If it is cast iron,not threaded steel, you can rent a chain breaker at any rental store--that will pop the pipe quickly.
Use rubber Fernco type fittings to add your new pvc pipe.
Pictures if you can--Mike--
diy718 10-25-2010 11:32 AM
My question was is the reduction in size ok?
Bondo 10-25-2010 04:51 PM
Ayuh,... What's it draining,..?? 1, 1/2" is pretty small...
braindead 10-25-2010 05:19 PM
Without knowing what it's connected to the answer is NO. :no:
oh'mike 10-25-2010 05:32 PM
Same answer---a restriction in a drain should be avoided.
