| DIY Forum | DIY Blogs | Photos | Woodworking | Extreme How To | Advertise | Contact Us |
Previous Thread
Next Thread
More On This Topic
How to Replace a Radiator With a Convector
by eHow.com
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
How to Replace a Toilet Fill Valve
by Expert Village
We’re going to replace the fill valve on your toilet. I’m going to recommend a certain model which you cannot mix if you go to the home store. It’s pretty universal and it adjusts to all heights, which may have been the problem with... Read More »
Water Bleed in Shower Head
by Expert Village
Hey people, Don Golden here for Expert Village. We are still in the shower and we've got some work to do. We've taken off the valve cover here and before we get to work on this job, I want to bleed some of the residual water that is still trapped in the... Read More »
How to Replace a Toilet Water Supply Line
by Expert Village
As I’ve already mentioned, you want to replace your supply line if it’s one of the older kind which can crimp and break. Or if it’s in any way not working properly. So what you’ll want to do is shut off the water on the supply... Read More »
Shutting Off a Leaky Bathtub Faucet
by Expert Village
Hi this is Jon on behalf of Expert Village in this video clip we'll be turning off the water. Now some tubs have an access panel or you can actually reach into the wall and they'll be a shut off valve located in the wall that will just shut off the water... Read More »
