Removing Cast Iron In Ceiling - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-28-2011, 02:06 PM   #1
Removing Cast Iron in Ceiling
Do the chain cutters from Home Depot work well or will it split the cast iron making it more of a challenge in the long run?
I want to take all the plumbing in these pictures and move them to the bays in the wall. The cast iron piping all connects to the left, I was hoping to get the lines to the basement and then connect them where there is more room. I will also have to move the water lines and vent pipe.
Any thoughts or ideas on this?
Removing Cast Iron in Ceiling-plumbing-1.jpg   Removing Cast Iron in Ceiling-plumbing.jpg
badgerland is offline   Reply With Quote
Old 09-28-2011, 06:48 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 546
Chain cutters are great for snapping CI pipe. But looking at your pictures, I'd get a cordless drill with a 5/16 driver bit and remove the couplings instead of trying to wrestle the cutters over your head
Old 09-29-2011, 03:17 PM   #3
Should I be using 4" out of my toilet before I downsize it to 3" for the horizontal run to the basement?
Old 09-29-2011, 06:18 PM   #4
AlbacoreShuffle's Avatar
Id run 3" all the way.
Creating a funnel in a drain is not a good idea.
AlbacoreShuffle is offline   Reply With Quote
The Following User Says Thank You to AlbacoreShuffle For This Useful Post:
DangerMouse (09-30-2011)
Old 09-30-2011, 07:55 AM   #5
Thanks for all your help so far. I have 2 sinks and a shower (guest bath that rarely gets used) that are in the joist bays next to the large soil pipe that you see in the pictures. The sinks are already vented, so I am wondering if it makes sense to cut a hole in the middle of the joist and put them all into the soil pipe right away.
That way I will be able to get rid of two connections in the joist bays before I even get to the end of the wall where they have to go down stairs.
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
cast iron or pvc treerat Plumbing 1 03-29-2011 06:38 AM
Removing a Cast Iron Radiator MugsynSax Plumbing 1 10-05-2009 04:18 PM
Porcelain Quality on Steel and Cast Iron Tub? MrTubz General DIY Discussions 5 03-04-2009 05:24 AM
