-   -   removing bathtub faucet diverter (http://www.diychatroom.com/f7/removing-bathtub-faucet-diverter-116371/)
xconx 09-06-2011 01:50 AM
I have a belanger 3 knob bathtub faucet. There's a hot and cold knob and the third knob is the diverter for the shower.
http://i1110.photobucket.com/albums/...onx1/pict3.jpg
I want to remove the diverter to either replace entirely or just replace the rubber washer. I'm having the hardest time removing it.
This is what the diverter looks like.
http://i1110.photobucket.com/albums/...onx1/pict2.jpg
The next step, I removed the bolt that should be holding the diverter in place.
http://i1110.photobucket.com/albums/...onx1/pict1.jpg
What is the next step? Do I just pull?
I tried getting a pair of pliers to pull and a hammer to knock the diverter loose but it doesn't budge at all.
Just Bill 09-06-2011 06:22 AM
It should rotate out just like the other valvestems. That is exactly what it is, a valve just like the other two.
bob22 09-06-2011 07:20 AM
Lefty loosey.
xconx 09-23-2011 02:30 AM
Lefty Loosey did indeed help. I used the plastic head to turn the diverter out.
It is not really held in by threads, but the turning of the diverter help loosen it out.
I replaced with a new one and I simply pushed it directly into the hole.
bob22 09-23-2011 06:04 AM
Good for you! Why are you posting at 3.30 in the a.m.? Get some sleep.
techprincesse 10-10-2011 09:13 AM
This is my EAXCT same setup and mine stopped working a few days ago... Stays on shower all the time with only a trickle of water coming from the bath spout. Were you able to just replace a rubber washer and get it to work again???
xconx 10-10-2011 11:17 AM
In theory that should work and it's much cheaper than what I did. However, I didn't do that.
I just brought the old diverter to my local plumbing shop (including the plastic knob) and asked them for a replacement.
