Removing Bathroom Sink Drain Plug (glued Abs P-trap) ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-06-2013, 07:09 AM   #1
Rewards Points: 85
Removing bathroom sink drain plug (glued abs p-trap) ?
Hello,
I'm currently trying to remove the drain plug on a bathroom sink. The only problem is that I'm not able to remove the drain body/tailpiece from the vertical ABS pipe. The p-trap is glued (no slip nuts) so it doesn't leave me a lot of room to remove the drain body/tailpiece.
Is there a way to remove the drain body/tailpiece without cutting the ABS pipe ?
Any recommendations would be highly appreciated.
See photo below
westbank is offline   Reply With Quote
Old 09-06-2013, 07:18 AM   #2
DIY staff
Rewards Points: 7,174
It's time to buy a can of primer and glue and a trap adapter---
and a new 1 1/4" P-trap,
Cut the pipe near the wall so you can add the trap adapter---
What was the installer thinking when that was all glued together?
joecaption (09-06-2013)
Old 09-06-2013, 07:23 AM   #3
Rewards Points: 85
I really don't know why the plumber glued everything ?
I still can't figure out how he was able to install the drainbody/tailpiece when everything was glued. Any idea how he did it ?
Old 09-06-2013, 07:31 AM   #4
DIY staff
The only way that was done was to install the pop up drain first and then glue in the piping.
I doubt if that was done by a pro----
Old 09-06-2013, 07:35 AM   #5
Rewards Points: 85
It's a brand new house that passed inspection. I guess they don't think about maintenance when they do the inspection.
The more I think about it ... I'm pretty sure the plumber installed all the piping (glued everything together) then he installed the drain body/tailpiece onto the sink. Then he installed the sink. That the only possible way I guess ???
Old 09-06-2013, 08:04 AM   #6
PoleCat's Avatar
Rewards Points: 1,652
If the tail piece is threaded into the pop-up body then unscrew it first then you will have clearance to remove the remainder of the drain.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-06-2013, 08:08 AM   #7
Rewards Points: 85
Just looked at the drain body and the tailpiece is threaded into the drain body (I can see the teflon tape on the end of the threads). This would probably let me remove the drain body/tailpiece from the waste pipe (vertical abs pipe).
I wonder if I could do the opposite to install the new drain body ?
Old 09-06-2013, 08:19 AM   #8
PoleCat's Avatar
Yup. PIA but doable.
Old 09-06-2013, 08:20 AM   #9
Plumber
TheEplumber's Avatar
Rewards Points: 904
Cut the pipe at the trap outlet, loosen the trap nut and the whole thing will drop down.
Rebuild with a pvc/abs compression trap- you may need a SJ tailpiece extension, trap adapter, abs coupling and a piece of pipe.
Are you in LA?
Old 09-06-2013, 08:41 AM   #10
Rewards Points: 85
Ok. So I guess I should really rebuild it.
I wanted to avoid redoing the abs piping because I will need to add a fitting (coupling) on the horizontal section and when we will sale our house the inspector will assume that we had an issue with the piping.
Another question. How deep should the drain plug tailpiece go into the abs trap (vertical section) ?
Should I use this to avoid adding a coupling fitting on the horizontal
section:
I'm not in LA
Old 09-06-2013, 09:27 AM   #11
Plumber
Rewards Points: 904
A coupling is just a fitting used to extend a pipe. It doesn't mean there has been a problem.
Your tailpiece needs to only extend beyond the traps compression nut so it seals
I was curious about LA because I believe they build traps similar to that
Sent from my iPhone using DIY Forum. Watch out for spell check
Old 09-06-2013, 03:03 PM   #12
Rewards Points: 2,104
Cut that puppy.
Ghostmaker is online now   Reply With Quote
Tags
bathroom , drain , sink , tailpiece
Running water does not go down in upstairs bathroom sink :( dnharp Plumbing 3 02-17-2013 04:37 PM
Relocate bathroom sink p trap docknows Plumbing 3 06-13-2011 08:30 AM
Replace bathroom sink drain? Dave321 Plumbing 2 06-07-2011 12:37 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
Bathroom Sink Shutoff Valve, Supply Lines, Removing CathrynH Plumbing 9 01-10-2008 12:28 AM
