-   -   Removed plunger type drain assembly but bathtub still wont drain. Please help (http://www.diychatroom.com/f7/removed-plunger-type-drain-assembly-but-bathtub-still-wont-drain-please-help-70269/)
lydiarosestiles 05-01-2010 01:42 AM
Hi there, thanks for reading my post! I hope someone here can help me.
My bathtub is not draining at all so I removed the overflow plate and the linkage and plunger drain assembly. It is still not draining. I used a small auger to try to push through and see if there was a clog and it does feel like something is stuck?
My understanding of a plunger style drain is that the plunger slides up and down the drain and seals the drain opening?
So if I have removed the linkage and plunger what could be blocking my bathtub from draining?
Thanks again!
kennzz05 05-01-2010 03:21 AM
try plungeing the hell out of it
dont forget to seal the overflow or all plunged air will escape there
Just Bill 05-01-2010 06:03 AM
You are most likely running into the trap(drum or bell type if an older house), it is nearly impossible to get a snake thru them, even when they are working. That is your likely clog spot. As suggested, plunging may do the job. I prefer not to recommend chemicals, because if they don't work, someone has to deal with them. Ideally, that trap should be replaced.
lydiarosestiles 05-01-2010 11:59 AM
I had actually tried plunging it before the auger. It is an old house so it must be the trap! Thank you!:thumbsup:
