Remove Toilet Rough In - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-05-2008, 10:48 PM   #16
Expansion Plugs
dyier is offline   Reply With Quote
Old 02-15-2008, 07:00 PM   #17
I have posted a picture in the first post.
dgoldb1 is offline   Reply With Quote
Old 02-15-2008, 07:53 PM   #18
Handyman
Rewards Points: 512
I have also used a spin saw or a Dremmel saw blade to cut inside the pipe. I also like to spray paint the concrete in case later someone wants to find it.
canadaclub is offline   Reply With Quote
Old 02-25-2008, 08:38 AM   #19
What do you guys recommend I use in order to cover over the expandable plug in order to make the floor level above it? Concrete?
Old 02-25-2008, 08:43 AM   #20
Journeyman Plumber
Ron The Plumber's Avatar
Concrete is fine.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-25-2008, 09:35 AM   #21
Rewards Points: 1,910
Wouldn't a nice box/bench seat look good there? You could put it right over the existing pipe and not have to change a thing. Plus it would give you some underseat storage. And then it will be easy to add that bath in the future.
Old 02-25-2008, 09:47 AM   #22
I was thinking about doing something like this. This is an option.
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Installing an attach-to-floor toilet? johnny4321 Plumbing 5 11-22-2007 01:34 AM
Shower Body, Toilet Water Supply Rough helpless handyman Plumbing 5 11-06-2006 08:51 AM
